Results 1 to 19 of 19
Thread: Is hair clipper oil OK to use then?
  1. #1
    Senior Member patrickbateman's Avatar
    Join Date
    Sep 2008
    Posts
    101
    I know some swear by Tuf-Glide, but is regular Andis or Wahl hair clipper oil, which contains petroleum distillates? I think, OK to use?
    Thanks!
  2. #2
    Spyderco Forum Registered User
    Join Date
    Nov 2007
    Posts
    235
    well, its what I've always used on mine... haven't had a problem to date.
  3. #3
    Spyderco Forum Registered User dd61999's Avatar
    Join Date
    Jan 2008
    Posts
    629
    I believe it is just mineral oil.
    Someone correct me if I am wrong
  4. #4
    Join Date
    Apr 2008
    Posts
    129
    Generic 'food grade' mineral oil ('mineral oil, u.s.p.') is probably going to be more economical at the local rite-aid than a 'branded' mineral oil (and the food grade stuff will not go rancid on you if want to cut food with your Spydie). Just my .02
  5. #5
    Join Date
    Sep 2008
    Posts
    101
    Mineral oil, I have a bottle of the baby type (johnson & johnson or whatever) smells DIFFERENTLY than the Wahl or Andis clipper oil...maybe its just a scent added to it...
    I tried the mineral oil on my Native III, and it somehow made it tighter and harder to open...the Andis clipper oil made it right again, so I'm leaning towards it to use, but just want to be sure...
    I don't generally use my knives to cut food...just stuff that comes up around house etc (always exciting when it does)
  6. #6
    Spyderco Forum Registered User jujigatame's Avatar
    Join Date
    Apr 2007
    Location
    Massachusetts
    Posts
    902
    I'd imagine the clipper lubrication products may to be made to optimize performance under sustained friction and the accompanying heat, which is not the kind of situation you'll encounter with routine use of a pocket knife. That said, I can't think of a reason of the top of my head not to use it, so if it works well in your experience then I don't see why you shouldn't.
    ~ Nate
  7. #7
    Spyderco Forum Registered User Noble's Avatar
    Join Date
    Aug 2009
    Location
    Hawaii
    Posts
    403
    I use plain old mineral oil on mine. Im not sure if the clipper oil is the same stuff, but, my mineral oil is scentless (rather doesnt smell at all like the baby kind) and it does a very fine job if I need to wipe my blades down. Makes a nice even coat when storing my blades, even after wiping the excess off, the layer left behind does nicely. For moving parts, I just make sure they are grit free, thats the best way for me as there is no lube to soak up grime.
    The bitterness of poor quality lingers long after the sweetness of meeting deadlines is forgotten.
    _____________________________________________
    My Dream Knife: Paramilitary with FFG H1. GITD G10.
  8. #8
    Join Date
    Sep 2008
    Posts
    101
    Quote Originally Posted by jujigatame View Post
    Thanks.
  9. #9
    Join Date
    Sep 2008
    Posts
    101
    Quote Originally Posted by Noble View Post
    I agree, the only issue I ever had with non scented mineral oil (the stuff I have, I checked) is that it seemed to swell the Native III's movement somehow....but it DOES leave a nice coating on the blades like you say...
  10. #10
    Spyderco Forum Registered User Doc Pyres's Avatar
    Join Date
    May 2008
    Posts
    1,181
    I use generic brand, scentless mineral oil on all my knives, Native included, and it works fine. I've never had any problems, but I guess if you got some lint stuck to it, it could affect the action. Dry lubes get around that issue if you're not worried about food prep.
  11. #11
    Join Date
    Sep 2008
    Posts
    101
    Thanks....what is a dry lube then??
  12. #12
    Join Date
    May 2008
    Posts
    1,181
    Quote Originally Posted by patrickbateman View Post
    Isn't the Tuf-Glide you mentioned in your opening post a dry lube? I'm no expert, because I use mostly mineral oil, but I used some Tuf-Glide some years back, and it dried to a non-sticky kind of silicon coating. I think it would be classed as a 'dry lube'.
  13. #13
    Join Date
    May 2008
    Posts
    1,181
    When I first got into the only lube I had around the house was some old clipper oil that I got with a Panasonic hair clipper. It worked but not very well. I prefer the mineral oil I switched to, but a decent brand of clipper oil should be just fine. I don't really know what was in that Panasonic bottle.
  14. #14
    Spyderco Forum Registered User angusW's Avatar
    Join Date
    Mar 2009
    Location
    Hamilton, Ontario
    Posts
    1,493
    I forget where I read it, but someone mentioned using olive oil for their knives. I usually use Tuf-Glide but there have been times when I've wanted to cut up some fruit and had to go find another knife. So mineral oil sounds like a decent coating for blades.
  15. #15
    Join Date
    Sep 2008
    Posts
    101
    Thanks to all....I'm thinking either mineral oil or a clipper oil is fine then I guess...seems to be at least...
    No one has really said USE TUF-GLIDE AND NOTHING ELSE on our beloved spydies, so I'll continue on!
    Thanks again.
  16. #16
    Spyderco Forum Registered User MCM's Avatar
    Join Date
    Jul 2008
    Location
    Left Field......
    Posts
    2,750
    yes...
    More S90v & CF please.......
  17. #17
    Join Date
    Sep 2007
    Location
    South Africa Capetown
    Posts
    1,144
    I have used gun oil on my knives,which works wonders,and i actualy like the smell of it. I once used reel oil for fishing reels and things became sticky..the gun oil works superb..guess any thin machine oil where repeated friction is involved would work superbly.to me friction between moving metal parts causes more wear on a foldingknife than worry's about corrosion and the wear thereof..specialy on lockback folders..WRT vertical bladeplay etc..i think clipper oil is perfect..
  18. #18
    Join Date
    Sep 2008
    Posts
    101
    Awesome thanks!
  19. #19
    Join Date
    Jan 2007
    Posts
    603
    I've used 3 in 1 oil, graphite, White Lightning(dry lube for bicycle chains - goes on wet), Militec, and gun oil. Use just enough to lube it up and be careful to get the excess off and you should be fine. All have worked for me. When I use oil, I have to clean off the excess several times over dozens of open/close cycles to get it the way I like it.
    I would worry about olive oil getting rancid. If you're worried about the lube getting in your food(I'm not, I only put it on the pivot) then food grade mineral oil would be my choice.
    Gordon
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
