I have a ss delica that has some light surface scratches on the handle,any advice on how i can get these scratches removed?
Other than some light sanding, ???
Mr. Bill
Old guys just know stuff!
ATR PE
Chinook III
Lil' Temperance PE
Manix PE
Mini-Manix PE
Native Black Blade SE
Native III PE
Para Military (S30V)
Spyderfly
I've used fine (1500) sandpaper to sand it following the grind line, but if it's deep enough to catch fingernail then it won't work.
I use the green 3M Scotchbrite pads and they work really well on light scratches like from rubbing against keys and such. I learned that at the SFO from Gail.
Work EDC List
FRP: Nisjin Cricket PE, Bug
FLP: SS Cricket SE, ZDP Dragonfly2 PE
Tom Krein TK-1 neck knife carried traditionally
ChapmanPreferred,I found some of those pads at walmart,and when i got home i started using it and it took the scratches right off,it totally restored the knife to almost factory condition.Thank you for that great advice.![]()
Why would you want to remove the scratches? They are what makes an SS knife pretty.
