Results 1 to 11 of 11
Thread: Need expert advice...
  1. #1
    WhyNot's Avatar
    WhyNot is offline Spyderco Forum Registered User
    Join Date
    Apr 2006
    Posts
    737
    I noticed some discoloration on the blades of two of my knives. One is my newest C16PSBRG Goddard (I bet it came like this), another is Shabaria which I have for a couple of month. Both blades are made of VG-10. Is it typical for that steel? Any suggestions on how to get rid of it and prevent it from happening again?
    Does anybody else have the same problem?
    Is it a problem at all?
    Any help would be appreciated!
    Here are a couple of pictures to show what I am talking about.
    Attached Images Attached Images
  2. #2
    ronin203's Avatar
    ronin203 is offline Spyderco Forum Registered User
    Join Date
    Sep 2004
    Location
    alb,n.m. USA
    Posts
    522
    About all I can tell you is to try cleaning it with a sentry solutions tough cloth. I don't really know if this is common for this steel. I haven't noticed it on any of my vg-10 blades. The tough cloth will clean and protect it.
    if you find yourself in a fair fight, you did'nt prepare well enough. .." Hock Hochiem".. " An object at rest cannot be stopped". The evil bomber what bombs at midnight.
  3. #3
    Join Date
    Sep 2004
    Location
    The Netherlands
    Posts
    6,344
    Perhaps Fliz polish could also work to fix it. I've seen it do wonderful stuff in polishing up a blade.
    Wouter
    Last update: 05-13-2013 - WTC 2507 - Twitter
  4. #4
    Join Date
    Apr 2005
    Location
    People's republic of Madison
    Posts
    4,379
    My cento 4 has that. Dunno what I cut, nuthin' takes it off.
    More of what does not work will not work. Robin Cooper, Rokudan; Aikikai.
    There is great power in the profound observation of the obvious. John Stone, Rokudan; Aikikai
  5. #5
    gud4u is offline Spyderco Forum Registered User
    Join Date
    Sep 2004
    Location
    morrisville, pa USA
    Posts
    33
    The best oxide cleaner I've found is 'Tarnite', available in 9 ounce tins from True Value (you may have to mail order).
    Key ingredient is oxalic acid, which chemically digest oxides. For tarnishes such as pictured, some tarnite on cloth or paper towel should easily wipe away the oxidation with light finger pressure.
    This stuff is excellent for rust-removal on collector-value knives, where you would not want to use an abrasive material.
    Hope this helps!
  6. #6
    Axlis's Avatar
    Axlis is offline Spyderco Forum Registered User
    Join Date
    Sep 2005
    Location
    Georgia, U.S.A.
    Posts
    3,240
    I also have this happen to my VG-10! My Cento 4, Rescue Jr., and CF Harpy all have this slight staining which appears within a few days of use. I figured it might have something to do with my body chemistry, but who knows. It only stains certain places, and there are no signs of rust. IIRC though, the Harpy had a spot when I bought, and rest spread with use.
    I just checked my ArendT R, and it doesn't have any staining though...strange... and I use this one most of all!
    Maybe someone else will chime in with answers, this has always puzzled me
    Proverbs 16: 9 In his heart a man plans his course, but the LORD determines his steps.
    When you've got a Delica and a Dodo, everything else is just eye-candy!
  7. #7
    Stevie Ray's Avatar
    Stevie Ray is offline Spyderco Forum Registered User
    Join Date
    Sep 2004
    Location
    Virginia
    Posts
    1,542
    Quote Originally Posted by Mr Blonde
    Wouter
    Mr. Blonde is right on with this suggestion ... Try the Flitz. If the stain is deeper and the knife came from a dealer then send it back for an exchange.
    Steve
  8. #8
    Zac's Avatar
    Zac is offline Spyderco Forum Registered User
    Join Date
    May 2006
    Location
    Lutherville, Maryland, USA, Earth, Solar System
    Posts
    1,506
    Never Dull cleaner, and then Metal Glo polish will take it out no problem.
    WARNING: Sanity not guaranteed.
  9. #9
    WhyNot's Avatar
    Join Date
    Apr 2006
    Posts
    737
    Thanks!!!
    I have to admit - I did not have any clue about "sentry solutions tough cloth",
    Tarnite, Flitz, or anything else recommended here What made me feel somewhat better was that people I talked to in Home Depot and Love's did not know about that stuff neither. But Ace Hardware had both Tarnite and Flitz! The guy in the store recommended Tarnite, so I bought it.
    In no time my Shabaria was shining like never before! It took much more effort to clean up Goddard. But it also looks good now.
    Thank you, guys for sharing your knowledge!
    PS. Axlis, Do not worry about your body chemistry. You are fine! My knifes got stained without being used for EDC
  10. #10
    spydutch's Avatar
    spydutch is offline Spyderco Forum Registered User
    Join Date
    May 2005
    Location
    Assen (Drenthe) the Netherlands
    Posts
    6,194
    I had a similar spot on my Delica 3.
    Polished it away with White Lightning Metal brite
    VERY PROUD OWNER OF A CALY III/SE #043
    ....AND A FG(PARA) MILITARY/SE IN CPMD2(thanx Sal)
    ...I would love to have one in full SpyderEdge
    Thanks for making me the Avatar, Dialex
  11. #11
    224477's Avatar
    224477 is offline Spyderco Forum Registered User
    Join Date
    Jan 2005
    Location
    Slovakia
    Posts
    4,156
    I would say its typical, sorta black like-shades..
    Try metalGLO.. Or forget it
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
