Originally Posted by
HoB
Welding?????
I will open my big mouth here and risk that I am putting my foot into it, but there is no way in hell you are going to weld any blade without screwing up your temper. Welding requires to locally heat the steel to its melting temperature...that is way BEYOND the austenization temperature! And if you want to get a weld with maxium strength you have to aneal the workpiece at a temperature which is also around or beyond the austenization temperature.....either way you are screwed.
Just my idea too. Maybe it was not about welding but grinding?
