Results 1 to 5 of 5
Thread: Best sharpening angle for S30V?
  1. #1
    Spyderco Forum Registered User KBR's Avatar
    Join Date
    Sep 2004
    Location
    Corpus Christi, TX
    Posts
    1,535
    I keep a 30 degree angle on my S30V Millie, mainly because I love the exreme sharpness at this angle. However, I am curious if the S30V can chip easily, or be brittle, just as the CPM440V. If this is the case, I'd rather sharpen at the 40 degree for a little tougher edge.
    For those of you who are more familiar with S30V, which would be the best sharpening angle?
    Thanks.
    Survive, Adapt, and Overcome...
  2. #2
    Spyderco Forum Registered User chux's Avatar
    Join Date
    Sep 2004
    Location
    United Kingdom
    Posts
    400
    I've not heard of, or experienced, S30V chipping at 30 degrees. However, I have seen VG-10 chip when set at 30 degrees. I try to keep an edge on my delica (VG-10) of around 27 degrees and have had no problems.
    30 degrees with S30V should present no problems.
  3. #3
    Spyderco Forum Registered User J Smith's Avatar
    Join Date
    Sep 2004
    Location
    Harriman TN USA
    Posts
    7,082
    I keep my Military at 30 degrees with no problem.
    <img src=http://techhelpers.net/e4u/drink/trink36.gif
  4. #4
    Spyderco Forum Registered User Simple Man's Avatar
    Join Date
    Sep 2004
    Location
    Kentucky
    Posts
    2,036
    I sharpen my S30V Millie to 30 degrees and was pleased to find that it was actually profiled to 30 when I go it from the factory. I haven't had any problems with it.
    “…tractors don't have to look like Ferraris” – Sal <><
  5. #5
    Join Date
    Sep 2004
    Location
    Columbia, TN USA
    Posts
    1,332
    Ours takes, and holds the 30 degree sharpening angle, or 15 degree edge better then any other steel! RKBA!
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
