Hi, I’m looking for some advice from the Mule experts.
I bought a ZDP Mule second then decided to use the factory scales. The barrels in the scale kit will not pass completely through the scales. They only ‘fit’ from the presentation side and stop approx.1-1.5 mm before clearing the opposite side.
Given the concern around the brittleness of these particular mules and my
ham-handedness… should I
(1) try and bore the holes lightly or
(2) emery the barrels to get a better fit or is there an option (3)?
Thanks in advance.
Little help…
Little help…
'The future is already here;it's just not evenly distributed'
William Gibson
William Gibson
Re: Little help…
Personally, I would find the location on the hole it is binding up and use sandpaper wrapped around a rod
Mule Team Army 001
MNOSD 008
MNOSD 008
Re: Little help…
I'd do the same. Not necessarily that it's the right way to do it, more that it would be easier to hold the blade blank and sand it than hold the barrel and sand it. I would invariably flat spot that barrel if I tried to sand it.
- standy99
Re: Little help…
I would sand the barrels as they will be softer steel as they would not be hardened.
Cut a strip of sandpaper as thick as the barrel. Screw both screws into the barrel and place inside a vice or a locking wrench (like below)
It really shouldn’t take that long to sand them to fit through the mule holes. Try 120 grit wet and dry sandpaper
Re: Little help…
Always modify the least expensive part, if you have the option. That means adjust the barrels to hit the holes in this case.
Re: Little help…
Thanks to you all for your advice. It is very much appreciated.
I was able to look in the holes in daylight and could see a small burr in each one. Possibly from the final part of the laser cutting process…
I used a small diameter diamond file to ‘gently’ remove them. Checking the barrels fit as I went.
The knife is now scaled.
William Gibson
William Gibson
Re: Little help…
I had the same trouble getting the threaded insert in my mule. It would start on one side, but not the other, even if I flipped the mule over. I was considering doing without it, it was the middle hole and would have glued the screws in place for appearances. I got it sanded to the point where I could tap it into place. Looks good, and it’s NOT going anywhere! Now if I ever sell it, I can claim I hand finished it. Glad to hear you got your handles fitted too.Ngati Pom wrote: ↑Tue Jan 17, 2023 4:06 pmThanks to you all for your advice. It is very much appreciated.
Re: Little help…
Hand finished…Brant wrote: ↑Tue Jan 31, 2023 5:07 pmI had the same trouble getting the threaded insert in my mule. It would start on one side, but not the other, even if I flipped the mule over. I was considering doing without it, it was the middle hole and would have glued the screws in place for appearances. I got it sanded to the point where I could tap it into place. Looks good, and it’s NOT going anywhere! Now if I ever sell it, I can claim I hand finished it. Glad to hear you got your handles fitted too.Ngati Pom wrote: ↑Tue Jan 17, 2023 4:06 pmThanks to you all for your advice. It is very much appreciated.
I might have to use that too.
William Gibson
William Gibson
Re: Little help…
Diamond file great for the burrs. To open a hole one might try diamond bits and a moto tool. Those diamonds do a wonder on glass. I loaned my set to a lady that does glass doo dads from bottles.
Just a crotchety old curmudgeon who has seen a thing or two
