Question for owners of Sun and Moon Chaparral
Soanso McMasters
Post by Soanso McMasters »
I just received my Sun and Moon Chaparral and it has arc shaped scratches on the ricasso around the writing, as though it is scraping or dragging when opening and closing and consequently scratching it. Is this a normal feature for this particular knife or is mine somehow out of spec? Thanks as always!
5-by-5
Re: Question for owners of Sun and Moon Chaparral
Post by 5-by-5 »
Mine doesn't have scratches and I've had it since it was released.
araneae
Post by araneae »
Sounds like rubbing on the liners, I'd probably try to exchange it if it was me. Haven't seen this on any of my Chaps.
-Nick
Last in: N5 Magnacut
Worm
Post by Worm »
I have two Chaparrals (CF version with full liners & LW version with nested liners):
Both of them had after several hours of fidgeting on the couch (no real cutting use) already scratches on the ricasso.
The Chaparral has very tight tolerances. I always thought it is inevitable if one is not very careful during opening.
Have the same issue with many Seki LW FRN models.
Not a deal breaker for user knives.
But over a specific price point (like the Sun & Moon Chap) not ok.
carrot
Post by carrot »
I don't have that one, but my other Chaparrals have scratches at the ricasso.
5-by-5
Post by 5-by-5 »
carrot wrote:
Tue Nov 09, 2021 10:52 am
Yeah. Even if I did have scratches I wouldn't be concerned. I don't own safe queens.
Pokey
Post by Pokey »
My CF Chaparral has scuff marks on the ricasso where it meets the edge of the blade. It happens because my thumb is pressing the blade sideways when I open it, and it's scuffing the liner. It doesn't really worry me.
rashman
Post by rashman »
my sun & moon didn’t come with any marks on it.
over time (got this one on initial drop) it has developed a crescent shaped wear line above the pivot area but below the scale line on the sun side, it’s only visible when your moving the blade - can’t see it open or closed.
current fav’s: K390 SS Stretch, PM2 CruWear Mircata, P.I.T.S., Subway Bowie
Soanso McMasters
Thanks for the replies folks. I talked to someone at Spyderco and they said it shouldn’t be leaving lines so I will get the issue resolved.
Soanso McMasters
rashman wrote:
Tue Nov 09, 2021 2:29 pm
Mine has multiple on each side clearly visible upon the very first opening of the knife and they are spread throughout the riccaso and show when the blade is open. I wouldn’t worry on a working knife but these are showpiece gentlemen’s knives and I paid extra over the FRN model purely for the aesthetical reasons. Given that it’s brand new I’ll have the problem rectified.
rashman
Post by rashman »
lookin at Pokey's response- mine is wear from use, i carry this one lefty thus the rub from opening pressure on the sun side.
yerp, Soanso - urs was not correct for NIB
sn0wman72
Post by sn0wman72 »
No marks on any of the Chaps I have...sounds like an alignment issue
lilshaver
Post by lilshaver »
Mine looks pristine also and carried every Sunday.
Ramonade
Post by Ramonade »
The rotation of the opening-closing is starting to leaves some marks at the same spots on my Chap LW.
metaphoricalsimile
Post by metaphoricalsimile »
Mine had a little bit of scraping sound/feeling on open/close but I adjusted the pivot and it went away. These knives with two pivot screws need the tension to be balanced between them properly for good centering and action.
austrian_spyder_fan
Post by austrian_spyder_fan »
I have also scratches on my Chap CF.
Didn't see them in the Sun and Moon amd Maple.
ASF
Ramonade
Post by Ramonade »
Since there is liners there, it's most certainly coming from the CTS-XHP rubbing on it.
Soanso McMasters
Just got my replacement and no scratches. The Chaparral is such an excellent knife!
