Yeah, I was a bit hasty (I made a pun ! LOL) when I tried to adjust my Manix 2. I don't currently own a soldering iron. Do you recommend applying heat with a hair dryer in order to loosen the Loctite first ?Surfingringo wrote:When a torx bit strips a screw, its most likely not an issue with the bit. (edit: That is probably too general of a statement. A cheap bit can indeed be the problem but I haven't experienced that with the Huskys or the Kobalts. Anyway...) Either the screws are too soft (never had this issue with Spyderco hardware), too much force is applied, or the wrong size bit is used. The last one can happen with torx screws because sometimes the bit that is one size too small can be used but it will almost certainly strip the screw. I always check to make sure i'm using the largest bit that the screw head will accept.HorserloverFat wrote:I hope that these bits work as the Home Depot set really stripped a screw on my Manix 2. Thanks.timlara wrote:I have that Lowe's set. It's decent for the price. My only real complaint with it so far is that it doesn't stay snapped together very well, so if you carry it in a backpack or whatever, it tends to come apart. The driver is supposed to snap through those two handle holes and hold the whole thing folded shut, but it doesn't really stay in place.
The bits themselves seem fine, though.
I will say that I saw that one you have in the store and elected to pass on it. Looks to me like that thin handle would be more difficult to apply even pressure to. I would probably go ahead and get the one you are looking at as it looks to be more user friendly. Just remember, when dealing with small torx screws, "If it won't go; force it" is a poor mantra. :D
BTW Have you heard about Mary Lee ?
http://abcnews.go.com/US/video/meet-mar ... r-30902691" onclick="window.open(this.href);return false;
