Why are my signatures not showing?
For some reason, my signatures are not showing. I noticed others whose signatures do not seem to be showing, either. What is the reason?
Re: Why are my signatures not showing?
I also see I have been demoted from "Senior Member" down to "Member".
- xceptnl
The signatures did not seamlessly roll over from the old forum. You were able to get your avatar added, the signature settings are in the same location. Also the "Senior" was changed on the admin side so now all members are "Members"
Signatures still do not show.
- xceptnl
Mine is, and I have seen several other members who have their signatures working.Doc Dan wrote:Signatures still do not show.
Mine are not. Odd.
User Control Panel > Profile > Edit signature
After editing make sure you click on Submit.
Also, try a small signature without any formatting to see if that works.
- I welcome dialog, as long as it remains cordial, constructive and is conducted in a civilized manner. - Titanic: Blood & Steel
- You can fool some of the people all of the time, and all of the people some of the time, but you cannot fool all of the people all of the time. - Abraham Lincoln
Yes, I did all of that, three times, now.
Make sure under User Control Panel > Board preferences > Edit posting defaults > Attach my signature by default is Yes
Thank you RamZar!RamZar wrote:Make sure under User Control Panel > Board preferences > Edit posting defaults > Attach my signature by default is Yes
My pleasure.Doc Dan wrote:Thank you RamZar!RamZar wrote:Make sure under User Control Panel > Board preferences > Edit posting defaults > Attach my signature by default is Yes
- kennethsime
Testing here to see if my signature shows!
- kennethsime
One more test
Edit: for those who're coming here looking for info, this one successfully shows my signature. The difference? I double-check both steps listed above, but also removed all formatting from my signature.
- demoncase
6 month Necropost.
I have followed all of the above steps several times and my signature does not show.
It's all a bit puzzling!
EDIT- and the second I post in this thread it magically appears to make me like a right plum. :o
As you were- carry on :D
