Some folks have asked just how this is done, well I found one little bit of
scrap soft leather that I could make this little tutorial up with, our friend
John M Cohea is sending me some soft leather, really appreciate that to John!
A tip, you will need SOFT supple leather, not the kind you would normally use
to make a sheath with, but something like deer skin, or Elk or Buffalo makes
for a nice soft strong leather fob
First you slice a piece of leather that will fit into the thong hole of the knife
using a ruler to keep the piece from moving, slice one side straight and then
slide the ruler back to the proper width and slide while pressing down firmly
on the ruler to keep the leather from moving on you.
Then slip the piece through the thong hole so you have equal parts on either side,
take a sharp knife, I like the wharncliff for this for it's direct point
and make two slits, each about as long as the leather is wide and spaced about
that same distance apart, like this;
then push one end through that first hole
then pull the leather snug up to the knife, you want to make it so the fob won't
slide around in front of the blade
with that up as tight as you want it to be, doesn't have to be tight tight, as you
do want it to pivot a little bit, just not a big loop, then on the other side you
will also cut in two slits, like you did on the previous piece;
and now we just alternate, insert the other leg into the newly made slit
and then put the other one through the other leg, part of that braiding thing...
until you end up with both 'good' or finished sides of the leather to the outside
I then take and roll the braid between my thumb and index finger, rolling it to
make it a bit smoother fitting
next post for the bead part, limit of 10 images per post...
Making a braided leather fob and attaching a bead
- Gary W Graley
"The Road to **** is Paved with Good Intentions!"
Take the time to read your Bible Now, don't be left behind...
Psalm 1
Psalm 1
- Gary W Graley
Found a box of beads in Walmart that had holes big enough to get the leather through,
fairly inexpensive for the box of various colours
Slide the bead onto the leather up past the braided section, cut a wedge of firm
leather to put in between the two pieces
insert the wedge up against where the braid ends and slide the bead down on top of that,
pulling tight, not SUPER tight as it won't take much to wedge it on
ending up with the wedge like this;
The distance the bead is from the end of the handle is kinda important as you want to
be able to hook the bead with your pinky to help draw the knife from the sheath,
so depending on your hand size you will have to experiment with that distance.
if you have an expensive bead, you might want to put a dot of glue on the leather
wedge just to keep it from ever slipping free and losing that bead!
I've recently changed to using some gasket material, it has cork and rubber in it's making
and that works VERY well as the wedge, no need to glue anything with that.
That's it gang, hope it helps clear some things up,
G2
G2
Psalm 1
Psalm 1
