Some Examples of my Kydex Sheath work for Spyderco Knives...
- Banned
Recent Examples of my Sheath Work, for Spydercos...
So, I thought I would start a thread, show off some of the sheaths I have made for Spyderco knives...
An Aqua Salt, customer wanted yellow so he could see it in the water, though this yellow likely does not match the yellow handle...
For the Street Beat, with a bit more retention than the stock sheath... Set up for 45 degree carry with a Spyderco G-clip...
And a couple of Mules, with BHK Scales on them...
Thank you,
Marion
Thank you,
Marion
Marion David Poff
- Banned
Kydex and it's competitor, Boltaron aka Concealex are plastics, that can be heat formed to make a knife sheath.Evil D wrote:What exactly is Kydex anyways? I keep seeing and hearing about it...how do you work with it and mold it like that?
The Spyderco Moran, Street Beat, Temperance 2, Swick gen 1, Forester, Forager, Woodlander, and Dayhiker all came with Concealex/Boltaron sheaths. The Spyderco Temperance came with a Kydex sheath.
Functionally, the reason people like them is that they can be made to retain the knife very strongly, without the need for a secondary strap or catch. Enough retention to wear the knife upside down.
They are impervious to water, so they won't go soft and allow your knife to cut you. Nor will they absorb water and transfer it to your knife.
They are modular, in that one sheath can be used with multiple different carry attachments to serve a number of different functions. If made well.
The downside is that they take a certain degree of skill to get right. There are only so many shops offering them. And they are more expensive than many of the other alternatives.
Essentially so.Visual Articulation wrote:Nice work , isn't it a thermal plastic. you heat it up lay between stiff foam core layers to mold it around whatever u are making a sheath for...?
Best,
Marion
Marion David Poff
- sharpguitarist
- Banned
- Banned
- sharpguitarist
- Banned
Thank you!sharpguitarist wrote:you sir, are a very talented sheathmaker!
those look great! i especially like the one with the firesteel.
keep up the fantastic work.
later,
don
Thank you for your kind words.GoMeR wrote:Nice looking work Marion, how do you find the kydex holes hold up without having a rivet in them? Ever had a problem with a tear or wear? The Bushcraft sheath with the fire steel is very nice!
I have experienced no issues with them, nor have I heard of issues such as tearing or excess wear and it is a common design trait with other kydex products. So, I have not be concerned with it.
As well, the eyelet/grommet/rivet adds distance for hardware to bridge, so I actually design my FireSteel Loops to bolt into the holes without the eyelet.
Did you ever get your ZT sheathed up?
Best,
Marion
Marion David Poff
I have one of his mule sheaths. They are a solid piece of construction. :)
"It's like he channels dead crazy people!"-Brock Samson
Officially corrupted by Sequimite
Own:E4W E4W trainer, D4W, D4W trainer, Centofante 4, Swick II, FFG E4 w/ foliage green G-10,Mule Team 5 and 6
Want list: ZDP Stretch, Original and New Yojimbos, Perrin PPT
My wish-existed list: More MBC-esque blades.
- Banned
- ChapmanPreferred
Marion,
Did you build your own kydex press or did you purchase one...or both? You can PM the answer to me if you like.
Thanks.
Doug
Thanks.
Doug
Work EDC List
BRP: CF Military S90V
BLP: Forum S110V Native
[SIGPIC][/SIGPIC]
Work EDC List
[SIGPIC][/SIGPIC]
- Banned
Shipped three Swick sheaths out today...
This is the new style I just worked up, and it will be the style I will offer with the Swicks, from now on...
Sand with ParaCord over Ballchain, makes a great neck knife, and the light colored sheath helps it blend in....
OD Green...
Sand with a Spyderco G-clip...
Thanks for looking!
Best,
Marion
OD Green...
Thanks for looking!
Best,
Marion
Marion David Poff
- sharpguitarist
- Banned
Thanks!sharpguitarist wrote:those looke awesome dude!
makes me want a swick.
got a ?
how did you fish that chain through the paracord?
i did it once.........once! what a pita. took me forever.
again, great work!
later,
don
To get the ball chain in... Cut the piece of paracord to length. Remove inner strands. Melt one end lightly, leaving other end frayed. Test to see if ballchain will fit through, if not, crush melted end with something (pliers, rock, teeth) this will give you just a bit more room, to allow the ball chain to pass. Grasp the melted end between thumb and finger, lightly. Push ballchain in. Repeat until it is through. Then, melt the other end, lightly.
I did those while watching TV. I like to do things like that in batches.
Best,
Marion
Marion David Poff
- Banned
- Banned
I have not done one, but I have not doubt I could build a sheath for one.Broad Arrow wrote:Can you do one for the Spyderco Warrior?
But, as I do not have the knife...
And, since Mike at http://www.rivercitysheaths.com/ not only has the knife, but is also the expert at sheathing this Wanner/Echanis/Taylor design.
I would suggest you contact him, and he will make a great sheath for you.
Best,
Marion
Marion David Poff
