Prediction: You will like this knife better than the Chief Salt or Chief LW.
Would you buy a Stretch XL Salt?
Re: Would you buy a Stretch XL Salt?
nevermind i got mine. ill have some pictures up after i sneak outta work for a bit.
finally got some h2 to test
only question now is what to dye it.
Beautiful blade, that hollow grind looks sweet. How do the ergos feel in hand?
I personally think It look great dyed some gray-green earthy tone
Current “dream collection” of knives
temperance 1, lil temperance 1 serrated leaf, black micarta calypso jr & calypso, cocobolo kopa, stainless serrated harpy, stainless cricket
Personally i think the stretch xl is the best feeling spyderco in the handTristan_david2001 wrote: ↑Wed Dec 27, 2023 5:00 pmBeautiful blade, that hollow grind looks sweet. How do the ergos feel in hand?
viewtopic.php?t=92147Tristan_david2001 wrote: ↑Wed Dec 27, 2023 5:00 pmBeautiful blade, that hollow grind looks sweet. How do the ergos feel in hand?
Windward wrote: ↑Wed Dec 27, 2023 5:11 pmPersonally i think the stretch xl is the best feeling spyderco in the handTristan_david2001 wrote: ↑Wed Dec 27, 2023 5:00 pmBeautiful blade, that hollow grind looks sweet. How do the ergos feel in hand?
For a folder I agree it’s up there.. I have much more experience in the hand with the straight spine stretch 2 vg10 since I own one, and I’ve only briefly held the cruwear g10 stretch xl in store and I think I slightly prefer the stretch 2’s handle proportions, a little more stout and just the right length for my hand. But the ergos are obviously very similar. If they made a hollow ground ss stretch 2 I’d probably break down and buy one. One of my favorite harder use folding knife designs
Thanks checkin it out!vivi wrote: ↑Wed Dec 27, 2023 5:20 pmviewtopic.php?t=92147Tristan_david2001 wrote: ↑Wed Dec 27, 2023 5:00 pmBeautiful blade, that hollow grind looks sweet. How do the ergos feel in hand?
here's a look at the tip profile & a comparison with a pe pacific salt 2 tip. this pacific salt has a thinned out edge but the tip is otherwise stock, not one of my thinned out tips.
it's meaty but not quite as beefy as the pacific.
for comparison here is a chief on the left and the vg10 ffg stretch xl on the right
kinda sad seeing the inevitable dethroning of the pacific salt. been a favorite of mine for a very long time now. I wanna say I got my first pinned pacific 1 around 2008 or 2009.
the stretch ergos always worked better for me than the endura.
gonna hold off on buying 17 pre-need backups like I did with pacific salts until I handle the chief salt though. that one could still end up being the best out of the three for me. we'll see.
- cabfrank
This knife is superb.
Wartstein and Windward, excellent points. It epitomizes the everything you need, nothing you don't line of thinking.
vivi, you could dye it rasta again. I know you like that on your Pacific. Orange would be great too.
- cabfrank
By the way, vivi, the Pac Salt has been your champ for a long time. It had to end some day I suppose.
Chiming in on ergos. I've always wanted to like Stretch ergos (I own just two), however the Stretch has a sizeable hump (belly?) beneath the ring finger (on the regular Stretch at least, don't know under which finger the hump would land on an XL). The hump messes with a favorable grip for me, somewhat. Don't know why the ring finger needs to have the large cross-section of handle to circumnavigate. I've been tempted to sand the handle hump down in size, as I do on mules, but have never done it...it would ruin the FRN border and probably not look good.
I've wondered if the Stretch's designer has a ring finger that is as long or longer than his middle finger? Might explain it. My ring finger is shorter than my middle finger. (Oddly, and completely off topic, one author - Dr. Agus - writes that a relatively long ring finger in women predicts osteoarthritis! Weird.)
Bolster, I thought the same thing about the Rock Jumper and Leaf Jumper. I have wondered if it would feel better with the palm swell moved slightly forward more towards the center. As of now it favors the rear. I'm sure there is a reason or thought process behind it. I am curious what that is.
#normalsizedhandproblemsBolster wrote: ↑Wed Dec 27, 2023 9:29 pm
if anything I could go for a slightly taller handle. works good for me as is though.
Hey Vivi,
Be sure to show us what color(s) you used to dye it.
Hi Bolstero & JSumm,
I designed both the Jumpers and all of the the stretches. The swell is a compromise to try to fit all hand and finger shapes. Nothing works perfectly for everyone. I use my hands and the hands of a few in the office to refine our early designs. If it didn't work for me, I'd sand it to fit. Looks be damned.
The swell is swell. I wish the Endura had the swell.
If it comes on PB washers and SE Magnacut, then maybe.
Thanks Sal! I personally prefer the swell. I was just curious if there was a reason it wasn't centered in the grip. Seems to favor the rear end of the handle. Maybe it gives a better hold for the stronger part of the grip being the first two fingers?sal wrote: ↑Wed Dec 27, 2023 10:54 pmHi Bolstero & JSumm,
What's funny is the the lack of of pb washers is one of my favorite things about these linerless salts. One less thing to worry about corroding, as ive had pb washers do. Internally, the knife has only 2 parts. Lot less to worry about when the knife is working in, on, under and around salt water everyday . One of the beautiful things about spyderco though, is there is something for everyone.
Ill also say, maybe its because its a larger blade, but this might be the smoothest backlock salt ive ever had. Outside of a little lube around the pivot, didnt even need a loose pivot screw and it flicks right open. Everybit, if not smoother than, standard vg-10 models ive had with washers.
Windward wrote: ↑Thu Dec 28, 2023 6:33 amWhat's funny is the the lack of of pb washers is one of my favorite things about these linerless salts. One less thing to worry about corroding, as ive had pb washers do. Internally, the knife has only 2 parts. Lot less to worry about when the knife is working in, on, under and around salt water everyday . One of the beautiful things about spyderco though, is there is something for everyone.
Along your lines and I don´t hesitate to reiterate what I´ve said in another thread already:
To me these Seki Salt in a way are the pinnacle of ingenious knife designing:
So few parts ("including", yes NO washers!), so light, but still so strong, perfectly working and capable.
