HAP40 Delica and Endura
- jimmyjohnjohn
Re: HAP40 Delica and Endura
I was looking at HAP40's composition last night. It has a ridiculous amount of cobalt, around 8-9%, iirc. Doing further research, it looks like it's a particular type of high speed steel, type 42.
https://en.wikipedia.org/wiki/High-speed_steel#Types" onclick="window.open(this.href);return false;
One thing worthy to note is that it's relatively more resistant to chipping.
Edited to add: HAP40 has more tungsten than standard type 42, which should mean that HAP40 has relatively more wear resistance.
After reading reports of unbelievably sharp Hap40 Enduras, I was surprised to find mine struggling with paper out of the box. After a quick tune up it was having no problem though. Also, my copy came with a very crooked laminate line on the one side that slants all the way down to the edge of the blade.
Hey ScottG how is the lock ? Any up/down blade play ?
- captnvegtble
I just got mine in the mail today from Blade HQ, and there is Zero blade play. Nice centering of the blade. Great Color. I like it quite a bit... although mine also isn't very sharp out of the box, so I'm going to have to sharpen, which I normally do anyway.
Here are both sides of mine for looking at the lamination lines:
Zero blade play with a very strong lock upelena86 wrote:Hey ScottG how is the lock ? Any up/down blade play ?
The lamination line in the first image looks normal, but in the second image (the other side) it is almost hard to notice as it is so close to the bevel and does eventually run into the bevel. Obviously this should not affect performance in any way. Sorry for the cellphone pictures.
That lamination line is whack but since its hap40 sandwiched in between sus410 all the way to the top you always be cutting with hap40.
Still can only imagine how awesome a solid slab would have been vs clad. I had an extra SB E4 that I sold because the lamination line was so wonky on one side.
- bearfacedkiller
Yeah, I like the laminated blades and do not need perfectly even lamination lines but I would be unhappy with them like that. They shouldn't be hitting the bevel IMO. Bummer. I should function just fine but still. I have a Super Blue Endura, Stretch and Delica and none of them have even lamination lines but none of them look like that. The lines are all way above the bevel on mine.
I wonder if this is caused by the steel or the thickness of the layers. I once read about this process and it said that they start with three layers that are about an inch thick and then roll it out into sheets of the desired thickness. If this steel is made that way then the variations in the laminations lines from one knife to the next could be caused by varying thicknesses of the layers rather than an uneven grind. It may have to do with quality control at the foundry and not at the manufacturing facility.
- PayneTrain
Yeah, I mean all things considered, I think it's quite an impressive feat to have the lines they do on such a thin piece of material ground at such acute angles. I still marvel at my SB Lady Bug because of how thin the blade is, yet it is still 3 layers of metal.
Speaking of which...Dragonfly?! Soon please?! Thanks!! :D
"Be the person your dog thinks you are."
Newly acquired. Perfect all around!
Awesome shot lo8el! Love seeing these pictures! Keep em coming! Only thing keeping me going until my KC Delica pre-order comes around... Anyone else have minor heart attacks every time your get the "Friendly note reminder" email? Just email me when its en route!!!
Nice to hear it performs well. I read elsewhere that it is comparable to M4. I like M4. :)
- TheOutdoorNerd
Still no word on when the Delicas are going to hit the streets?
It gets my hopes up when I see HAP40 and Delica in the same thread name
I haven't used my Endura a huge amount, but I noticed today it didn't shave arm hair as well as new so I touched it up, maybe 10 strokes per side on the Sharpmaker fine rods, and it seem to pop arm hair better than most of my knives. I was about to shave, so on a whim I lathered up and shaved a swath on my cheek, and darned if it didn't do almost as well as my razor.
Note to self: Less is more.
My local dealer had three HAP 40 Enduras left and I took the one with even cladding lines:
Put it through my usual routine of thinning the primary bevel until it was ~0.030" thick at 1/4" behind the apex and ~0.010" at 1/32" behind the apex with a Norton Crystolon coarse and cleaned up with a Sigma Power Select II 240x stone.
Edge bevel at ~8 degrees per side created freehand with a Sigma Power Select II 240x stone.
Edge bevel polished freehand using SPS-II stones in a 1,000 -> 6,000 -> 10,000 -> 13,000 progression.
Apex set with a micro-bevel using a Spyderco Sharpmaker with the fine rods on the 15 dps setting.
- SpeedHoles
Thank you! It really helped that the factory grind on this one was basically perfectly centered so the edge bevels came out matched without having to do any extra work on one side on the primary grind.SpeedHoles wrote:^ Beautiful work!
- HarleyXJGuy
I needs some HAP Delica in my life.
