Show your mods!
JAfromMN
Re: Show your mods!
#2501
Post by JAfromMN »
Not much of a mod but a nice restore for a member
demoncase
Re: Show your mods!
#2502
Post by demoncase »
That is truly a work of art sir- Nice one :)
Holland
Re: Show your mods!
#2503
Post by Holland »
JAfromMN wrote:Not much of a mod but a nice restore for a member
Very nice!
Made the holes larger on my chaparral handle
SpeedHoles
Re: Show your mods!
#2504
Post by SpeedHoles »
That looks pretty neat with the exposed liner edges inside the holes!
Going back to Caly.
Re: Show your mods!
#2505
Holland wrote:Made the holes larger on my chaparral handle
What a difference the with the liners showing! Great mod. Are those holes tapered? Any pics with the blade closed?
Holland
Re: Show your mods!
#2506
Post by Holland »
Thanks guys, I'll get a picture of it closed later today.
I pretty happy with it right now, but it definitely needs more sanding to make it perfect
JAfromMN
Re: Show your mods!
#2507
Post by JAfromMN »
demoncase wrote:That is truly a work of art sir- Nice one :)
Thank you very much.
I appreciate it.
This one's is all mine
ZDP -189 delica I had to dye black .
Image Image Image
I think I'll use it more if it's black
Holland
Re: Show your mods!
#2508
Post by Holland »
Slightly tapered. It needs more sanding :o
Holland
Re: Show your mods!
#2509
Post by Holland »
Double tap
Re: Show your mods!
#2510
Looks awesome. Tempting mod, but I'd have to buy another cause I could never harm my precious!
Holland
Re: Show your mods!
#2511
Post by Holland »
Thats the beautiful part about it being a production knife, if you mess it up, just buy a new one :D
I had to do it once already after making this mess lol:
I should have left it as it was
Re: Show your mods!
#2512
Very nice!
I can't decide if I want to do this on my Manix 2, or just trace the skeletonized liners and try to drill/grind out the same hole shapes that they have. I can't use the skeletonized liners because of how I've ground out so much of the handle behind the choil, and I don't wanna grind up a set of hard to find skeletonized liners.
Nasgul
Re: Show your mods!
#2513
Post by Nasgul »
Very nice!
Much better now than just the holes ! ;)
1st small hole seems not completely finished ?! I do not see all the steel.
:spyder: adds color to your knife addiction :D
Jazz
Re: Show your mods!
#2514
Post by Jazz »
Spencer, That looks 10 times better, and I thought it looked good before. :cool:
- best wishes, Jazz.
Re: Show your mods!
#2515
Added a deep carry wire clip to my Native5 LW. Still looking for a better screw (#2-56), but I'm happy with the results.
Found a screwdriver with the right size tip, heated it up with a torch, and pressed it into the FRN creating the two recesses for the wire, cleaned them up with a small file and razor, done. The stock clip will pretty much hide this mod if you decide to go back.
Jazz
Re: Show your mods!
#2516
Post by Jazz »
Not sure if I should put these here, but they are some of my pre Spyderco knives. I didn't realize I was a modder from way back.
FCB.ecky
Re: Show your mods!
#2517
Post by FCB.ecky »
This is my very first try at making scales for my tenacious. I learned a lot from this first set. I started with pretty thick wood. I'm already working on another set and it should go a lot smoother this time (especially considering it won't be my first time using this specific set of tools). By the way, those aren't stained, that is the natural color of the wood.
demoncase
Re: Show your mods!
#2518
Post by demoncase »
DutchBlades
Re: Show your mods!
#2519
Post by DutchBlades »
[quote="demoncase"][/quote]
I didn't notice the backspacers reflection in the weekly contest yet; great looking piece like this!
A tiger has claws.
A wolf has teeth.
An eagle has talons.
We, have Spyderco.
Grails: Abalone Mini Mariner, Ti ATR, WTC, Ti Lum Tanto
jabba359
Re: Show your mods!
#2520
Post by jabba359 »
FCB.ecky wrote:This is my very first try at making scales for my tenacious. I learned a lot from this first set. I started with pretty thick wood. I'm already working on another set and it should go a lot smoother this time (especially considering it won't be my first time using this specific set of tools). By the way, those aren't stained, that is the natural color of the wood.
Hey, nice Barcelona FC shield! I'm looking forward to seeing your next set of scales.
-Kyle
:bug-red
http://www.spydiewiki.com
