Yard Work - Nice Day
- Manixguy@1994
Re: Yard Work - Nice Day
8 yards delivered a few minutes ago . Just for around the house . Going to be busy . Dan
- ChrisinHove
Good thread! There is little better in life than watching other guys work hard!
- Manixguy@1994
I’m married to a professional landscaper . No rest for the wicked . We have a truck load brought in every year and rotate placement. Next year will be big islands to mulch . DanChrisinHove wrote: ↑Tue Apr 26, 2022 11:22 amGood thread! There is little better in life than watching other guys work hard!
Wow Dan! You do have a busy day ahead.
Last load I brought in were 2 scoops of rocks for a pad for me to drop my condenser units. It was a lot of shoveling but it always looks great when complete. By the way, the Tacoma can handle a scoop of rocks in the back. Just go slow....
- Manixguy@1994
That looks top notch ! Are you going to stain the trim or let go natural ? DanJSumm wrote: ↑Tue Apr 26, 2022 6:45 pmWow Dan! You do have a busy day ahead.
Just left it natural. Pine straw goes up against it the timbers. Down here in the South you don't want to use mulch. Even cypress can create a haven for ants. Ants and termites are a big problem. The rocks around the units help keep them clean with rain. Instead of mud and debris splashing on them it is mostly water that splashes back up.Manixguy@1994 wrote: ↑Wed Apr 27, 2022 5:37 amThat looks top notch ! Are you going to stain the trim or let go natural ? DanJSumm wrote: ↑Tue Apr 26, 2022 6:45 pmWow Dan! You do have a busy day ahead.
- Manixguy@1994
I never thought about climate and mulching but makes sense . We are changing out A/C and furnace this year . I’m waiting on quote for concrete in front of garage . Putting in a water drainage grate in front on doors to redirect water to behind garage . Concrete will be 6 inch thick . Dan
- Manixguy@1994
Almost done with mulch . Rain this afternoon and then business came in to power spray porches and deck to stain, stopped finishing. Only have between deck and house to finish up . Dan
Holy cow Dan! You and your wife have done an excellent job with that yard. Looks great! Grass is amazing and the islands look awesome!Manixguy@1994 wrote: ↑Fri Apr 29, 2022 4:04 pmAlmost done with mulch . Rain this afternoon and then business came in to power spray porches and deck to stain, stopped finishing. Only have between deck and house to finish up . Dan
- Naperville
Beautiful work, great effort!Manixguy@1994 wrote: ↑Fri Apr 29, 2022 4:04 pmAlmost done with mulch . Rain this afternoon and then business came in to power spray porches and deck to stain, stopped finishing. Only have between deck and house to finish up . Dan
You still get around very good physically. It shows.
- Manixguy@1994
Thank you , I was able to use my SXS Polaris for some of it in the front yard but had to wheel barrel quite a bit . I try to work in yard everyday and I walk as much as weather allows . Dan
This is a topic I can relate to! After being away at work all week, my trusty garden tractor awaits...and a wheel barrow that needs a replacement tire.
Barry
Bonne Journey!
MNOSD member 0032
Bonne Journey!
MNOSD member 0032
Barry
Bonne Journey!
MNOSD member 0032
Bonne Journey!
MNOSD member 0032
- Manixguy@1994
- Manixguy@1994
I have a no flat tire on my wheel barrel , so I can’t use flat tire as an excuse . We actually were using two to speed up the job . Of course everything was uphill when loaded .Fun ! Danbearrowland wrote: ↑Fri Apr 29, 2022 7:20 pmThis is a topic I can relate to! After being away at work all week, my trusty garden tractor awaits...and a wheel barrow that needs a replacement tire.
I had to drill a couple of holes for a new wheel mount, and when I lifted the drill out of the newly drilled hole the bit dropped out of the chuck and fell through a gap in my porch so slick that I couldn't do that once in a thousand years if I tried . Still had another hole to drill so back to the hardware store. Of course there's no easily accessible way to get the lost bit back... only me!
Barry
Bonne Journey!
MNOSD member 0032
Bonne Journey!
MNOSD member 0032
- Manixguy@1994
When I was just out of high school in the winter for a couple years I worked at a Chevy dealership doing some mechanical jobs and picking up and delivering cars . A brand new Chevy Impala had a rattle in the passenger door . I took inside door panel off and found a nut attached to a wire . So the nut would swing and hit the panels inside when turning. There was a noted attached to that said, “ How long did it take for you to find this nut ? “ A gift from the UAW on the assembly line. Danbearrowland wrote: ↑Sat Apr 30, 2022 7:45 pmI had to drill a couple of holes for a new wheel mount, and when I lifted the drill out of the newly drilled hole the bit dropped out of the chuck and fell through a gap in my porch so slick that I couldn't do that once in a thousand years if I tried . Still had another hole to drill so back to the hardware store. Of course there's no easily accessible way to get the lost bit back... only me!
They’re making me work Dan, plus the weather’s been against me so no wet lines for a couple of weeks.
Cheers Bloke! Me too my friend...
Barry
Bonne Journey!
MNOSD member 0032
Bonne Journey!
MNOSD member 0032
