Show your Mule
tcarltonw
Re: Show your Mule
#1741
Post by tcarltonw »
Word, appreciate it.
Ramonade
Re: Show your Mule
#1742
Post by Ramonade »
The Green Orange (that's its name now) is finished.
I did not have time to take good pictures already, but here's some badly lit shots :open-grin
And a small video :
barnaclesonaboat
Re: Show your Mule
#1743
Post by barnaclesonaboat »
@Ramonade That looks incredible! :hundred-points Nice work. What kind of burl is that?
barnaclesonaboat
Re: Show your Mule
#1744
tcarltonw wrote:
Thu May 18, 2023 3:04 am
First mule team handle finished(over the weekend but haven't had time to post the pics). I had made a handle for a kit knife from wood craft so technically I can't claim that this is my first ever. I really liked the feel of the thin Halpern scales so I worked off of that profile, they finished around .18" thick. This was originally a .5" thick box elder burl scale that I ripped in half(more like one third and two thirds haha). This was definitely a learning process and have some ideas on how to address whoopsies on the next one(received some advice from standy and would have been completely lost without the handle making guide put together by xplorer). Two biggest things I ran into was get the profile uniform(originally wanted to have the scales slightly smaller to expose the spine all the way around and that turned into having ~ 1/8" + of the heel sticking out so I gave up on that) to the spine without grinding the steel and the other doing the chamfer by hand. Talking to standy he suggested to leave the scales on, take it all the way to the steel, and then just sand out the marks on the blade by hand(correct me if I'm wrong there). As far as the chamfer I wanted something subtle but functional. I sanded it in first before finish sanding the flats by wrapping sic sandpaper around a .25" x 1.5" piece of wood and around a fine tipped sharpie for curved pieces.(wish I would have taken more pictures). What ended up happening is I lost most of the chamfer through the finish sanding of the flats so I will be doing that last next time around. In the end I took the flats to 400 grit with sic sandpaper then finished with two coats of Axe Wax.
tcarltonw that dark cerakote with midnight burl handles might be the coolest Mule I've seen!
tcarltonw
Re: Show your Mule
#1745
Post by tcarltonw »
[/quote]
[/quote]
Appreciate that sir!
BearShark44
Re: Show your Mule
#1746
Post by BearShark44 »
Ramonade wrote:
Mon May 22, 2023 4:23 am
The Green Orange (that's its name now) is finished....
@Ramonade - incredible scales, thanks for posting. Do you use corbys .1875" pins w/ .25" heads in these 3 spots on the handle? I'm about to work on my first one and looking to get that same even pin distribution on the same line. How do you get the mosaic pin at .25" through - drill the hole larger or layer the mosaic pin on top of the recessed corby?
:bug-white-red :camping MT39P-15V, MT33P-Rex76; Sage1-Maxamet, Endela-K390, Delica4-M390, PM2-K390, PM2-S30v, Dragonfly2-SB, AmbitiousSE-8Cr13MoV; others TBD
Ramonade
Re: Show your Mule
#1747
Post by Ramonade »
BearShark44 wrote:
Tue May 23, 2023 4:44 pm
Hi ! Depends on the steel. I always use only two corbys and a good slow cure epoxy, that's plenty enough. If the steel is not too hard I try to open the center 3/16 hole to 6mm (0.236") to use a mosaïc pin all through the scales and the tang. Otherwise, I simply cut two lengths of mosaïc pin and use it as a decoration. Corby bolts are really good fasteners, once there's epoxy everywhere in addition to that, it won't move anyway !
I just ordered some larger diameter carbide drill bits, to see how it goes :grin-smiling-eyes
Ramonade
Re: Show your Mule
#1748
Post by Ramonade »
Here's a second AEB-L Mule
Still stabilized elder burl and all.
The only different thing is the color of the liners, and of the wood :open-grin
Xplorer
Re: Show your Mule
#1749
Post by Xplorer »
Ramonade wrote:
Fri May 26, 2023 10:14 am
Here's a second AEB-L Mule...
Looks beautiful Robin! Great job!
@ckc_knifemaker on Instagram.
Ramonade
Re: Show your Mule
#1750
Post by Ramonade »
Xplorer wrote:
Sun May 28, 2023 10:04 am
Thanks a lot Chad :grin-smiling-eyes I found my style. Still working on making them disassembly ready though. I have a prototype right now, but I want them to be super close to the tang without having issue if you swap them on another Mule (not easy at all :grin-sweat )
Erion929
Re: Show your Mule
#1751
Post by Erion929 »
tcarltonw wrote:
Thu May 18, 2023 2:56 am
This one I did have done locally by Black Boar Rifles. I had a Rex 76 one done by a guy suggested off of blade forums. I like it so far, haven't been put past any general cutting tasks but if sharpening is any indication of its capabilities I see the edge holding for a while. I just posted this in the community sharpening post but I felt like it belonged in the mule forum as well. Hopefully that's kosher.
How does the Spyderco logo not get obliterated….like the blade steel markings…. when Cerakoting?
tcarltonw
Re: Show your Mule
#1752
Post by tcarltonw »
Erion929 wrote:
Sun Jun 25, 2023 11:35 am
They are a 2nd cerakote spray as close as possible to the original
weeping minora
Re: Show your Mule
#1753
Post by weeping minora »
I believe the question was regarding how the Spyderco Bug logo on the blade was preserved in the cerakoting process.
I'll confess my ignorance on how the cerakoting process works, but I could see (as in painting) some sort of adhesive cut and shaped like that Bug logo would/could preserve it in the process.
Make Knife Grinds Thin Again.
tcarltonw
Re: Show your Mule
#1754
Post by tcarltonw »
weeping minora wrote:
Tue Jun 27, 2023 11:32 am
It's not preserved... I believe a stencil is created and it's then cerakoted on top of the first layer of cerakote. Feel like I can't word good to explain it haha
weeping minora
Re: Show your Mule
#1755
tcarltonw wrote:
Wed Jun 28, 2023 3:34 am
Stencil was the word I was looking for! Makes more sense that what I was trying to say :grin-sweat.
Sublime looking Mule, by the way!!
CasperFatone
Re: Show your Mule
#1756
Post by CasperFatone »
Lately I’ve been strapped for time but really wanted to put my new 15v Mule to work. I decided to do a set of scales as fast as I could without compromising on quality. The result was this set of Purple Heart scales, done in 1 hour and 5 minutes. The tools used were a drill press, bandsaw, trim router, and belt sanders (2x72 and 4x48). This was actually my first time making a set of removable Mule scales but definitely not my first set of knife scales. Hope y’all like them!
Amateur maker of folding knives and addicted to modding Spyderco knives
Folding Mules- m398 liner lock, Rex76 compression lock flipper, 15v liner lock flipper, 15v LW compression lock flipper
Re: Show your Mule
#1757
CasperFatone wrote:
Mon Jul 03, 2023 8:20 pm
...The result was this set of Purple Heart scales...
Nice!! I like the taper seen in the spine shot, quite a lot. What's your strategy for keeping the purple, purple?
Re: Show your Mule
#1758
If Sophia Vergara were a knife, she'd look like this!
Ramonade
Re: Show your Mule
#1759
Post by Ramonade »
Bolster wrote:
Mon Jul 03, 2023 10:43 pm
I'll admit it, I had to google that name. But I'm gonna take that as a compliment to my contouring :grin-smiling-eyes
Re: Show your Mule
#1760
Ramonade wrote:
Tue Jul 04, 2023 11:03 am
I guess I should have said Brigitte Bardot instead...
